- Apr 20, 2016
- 105
- 307
K51 DS-78xxNI-I2 firmware repack for NVR_K51_BL_ML_STD_V3.4.80_160718
http://rgho.st/7xHv2ZRzs
Changes:
... instead of bastardized Hikvision's that only supported these:
If you have problems upgrading over https, try upgrading over http. I have not researched it extensively, but there appears to be a bug in firmware that causes https upgrades to fail at about 33%.
Enjoy!
Changes:
- PSH removed
- Added bp_read app that dumps bootparams (just run bp_read at console prompt). Yes, I also have bp_set that changes bootparams but I won't share it at this time.
- Full featured busybox supporting all of these:
Code:
[, [[, addgroup, adduser, arp, arping, ash, awk, base64, basename, bash, beep, blkid, blockdev, brctl, bunzip2, bzcat, bzip2, cat, catv, chat,
chgrp, chmod, chown, chpasswd, chroot, chrt, chvt, cksum, clear, cmp, cp, cpio, cryptpw, cttyhack, cut, date, dd, deallocvt, delgroup, deluser,
depmod, devmem, df, diff, dirname, dmesg, dnsdomainname, du, dumpkmap, echo, ed, egrep, env, expand, expr, false, fatattr, fbset, fdisk, fgconsole,
fgrep, find, findfs, flash_eraseall, flash_lock, flash_unlock, flashcp, flock, free, fstrim, fsync, ftpget, ftpput, fuser, getopt, getty, grep,
groups, gunzip, gzip, halt, hdparm, head, hostid, hostname, hwclock, id, ifconfig, init, inotifyd, insmod, install, ionice, iostat, ip, ipaddr,
ipcrm, ipcs, iplink, iproute, iprule, iptunnel, kbd_mode, kill, killall, killall5, klogd, less, linuxrc, ln, logger, login, logname, logread,
losetup, ls, lsmod, lsof, lspci, lsusb, lzcat, lzma, makemime, md5sum, mesg, mkdir, mkdosfs, mke2fs, mkfifo, mkfs.ext2, mkfs.vfat, mknod, mkpasswd,
modinfo, modprobe, more, mount, mountpoint, mpstat, mv, nameif, nanddump, nandwrite, nbd-client, nc, netstat, nice, nmeter, nohup, nslookup, od,
openvt, passwd, patch, pgrep, pidof, ping, ping6, pivot_root, pkill, pmap, popmaildir, poweroff, powertop, printenv, printf, ps, pscan, pstree, pwd,
pwdx, rdate, rdev, readahead, readlink, realpath, reboot, reformime, renice, reset, rfkill, rm, rmdir, rmmod, route, rtcwake, rx, sed, sendmail,
seq, setserial, setsid, sh, sha1sum, sha256sum, shuf, slattach, sleep, smemcap, sort, split, stat, strings, stty, su, sulogin, sum, sync, sysctl,
syslogd, tail, tar, tcpsvd, tee, test, tftp, time, timeout, top, touch, tr, traceroute, traceroute6, true, tty, ttysize, tunctl, umount, uname,
uncompress, unexpand, uniq, unlink, unlzma, unxz, unzip, uptime, usleep, vi, watch, wc, wget, which, whoami, whois, xargs, xz, xzcat, yes, zcat
Code:
[, [[, arp, ash, awk, basename, cat, chmod, cp, date, dd, df, dirname, dmesg, dnsdomainname, du, echo, false, find, free, getty, gzip, halt,
hostname, hwclock, id, ifconfig, init, insmod, kill, killall, linuxrc, ln, login, ls, lsmod, lzcat, mesg, mkdir, mknod, mount, mpstat, mv, netstat,
pidof, ping, ping6, poweroff, ps, pwd, reboot, renice, rm, rmmod, route, sh, sleep, stty, su, tar, test, timeout, top, true, umount, unlzma
Enjoy!
