[MCR] G1 firmware IPC_G1_EN_STD_5.4.5_170124 -PSH
Hello, can this be used on 2CD-2135F camera, which is apparently G1 platform (based on firmware release notes which I read)? Which camera did you use?
I think you are not considering the correct model number.
According to http://www.hikvisioneurope.com/portal/portal/Product Firmware/Front-ends/01--IPC/G1 platform (DS-2CD2XX5)/2XX5(non-Fisheye)/V5.4.5 170124/G1 V5.4.5 170124 Release Note--External.pdf DS-2CD2135FWD-I(S) is a G1 camera.
My DS-2CD2135F-IS unit clearly indicate they are G0's.
Code:
## Booting kernel from Legacy Image at 80007fc0 ...
   Image Name:   Linux-3.4.35-g0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3923896 Bytes = 3.7 MiB
   Load Address: 80008000
   Entry Point:  80008000
   XIP Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.4.35 (luoxiaobing@Cpl-Frt-BSP) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) ) #1 Tue Jul 12 16:10:53 CST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: g0
[    0.000000] MISC TAGS: mdio_intf=mii phy_addr=3
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 26112
And the out from within the interface.
Code:
prtHardInfo
Start at 2017____DELETED____
Serial NO :DS-2CD3135F-IS20160411AACH____DELETED____
V5.3.5 build 150925
NetProcess Version: 1.6.1 [14:22:22-Sep 10 2015]
Db Encrypt Version: 65537
hardwareVersion= 0x0
hardWareExtVersion= 0x0
encodeChans= 1
decodeChans= 1
alarmInNums= 1
alarmOutNums= 1
ataCtrlNums= 0
flashChipNums= 0
ramSize= 0x100
networksNums= 1
language= 2
devType= 0x22521
net reboot count= 0
Path:
Working Copy Root Path: /usr/local/jenkins/workspace/Frontend_BaseLine_Publish_Build/1779
URL: https://192.0.0.140/Camera/Platform/Branches/branches_frontend_software_platform/IPC_develop_branch/ipc_5.3.5_G0
Repository Root: https://192.0.0.140/Camera
Repository UUID: ____DELETED____,b>
Revision: 152103
Node Kind: directory
Schedule: normal
Last Changed Author: chendan5
Last Changed Rev: 152103
Last Changed Date: 2015-09-25 18:04:07 +0800 (Fri, 25 Sep 2015)
so unless you have a FWD at the end before the -IS I think you are in a similar boat to many of us here. Hoping something similar can be developed for the G0's. But as I understand they RSA key signing is the challenge.
That's certainly confusing for what just appears to be a FWD suffix to the model number.
Just to add to the picture, or maybe confuse futher, here is some similar info from a DS-2CD3335D - various references to G0 :
Code:
alastair@PC-I5 ~ $ ssh [email protected]
[email protected]'s password:
BusyBox v1.19.3 (2017-01-18 20:54:04 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# prtHardInfo
Start at 2017-10-13 21:56:52
Serial NO :DS-2CD3335D-I20150619AACH524222564
V5.4.41 build 170710
NetProcess Version: 1.7.1.179932 [14:53:09-Dec 10 2016]
Db Major Version: 1176
Db svn info:
Path: /Camera/Platform/Branches/branches_frontend_software_platform/db_process_for_5.4.20
Last Changed Rev: 233659
Last Changed Date: 2016-11-08 11:13:39 +0800 (Tue, 08 Nov 2016)
hardwareVersion    = 0x0
hardWareExtVersion    = 0x0
encodeChans        = 1
decodeChans        = 1
alarmInNums        = 0
alarmOutNums        = 0
ataCtrlNums        = 0
flashChipNums        = 0
ramSize            = 0x100
networksNums        = 1
language            = 1
devType            = 0x22501
net reboot count    = 0
vi_type            = 32
Path: /Camera/Platform/Branches/branches_frontend_software_platform/comm_bug_fix/cgi_fix/ipc_repair/ipc_5.4.24_g0
Last Changed Rev: 297913
Last Changed Date: 2017-07-10 21:23:14 +0800 (Mon, 10 Jul 2017)
# cat /proc/cpuinfo
Processor    : ARMv7 Processor rev 5 (v7l)
BogoMIPS    : 1695.53
Features    : swp half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt
CPU implementer    : 0x41
CPU architecture: 7
CPU variant    : 0x0
CPU part    : 0xc07
CPU revision    : 5
Hardware    : g0
Revision    : 0000
Serial        : 0000000000000000
And here from the head of dmesg :
Code:
# dmesg
[    0.000000] Linux version 3.4.35 (luoxiaobing@Cpl-Frt-BSP) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) ) #1 Wed Jan 18 20:56:06 CST 2017
