I have inherited a couple of Mazi Security IDH-32XR cameras which I suspect are based on Hikvision DS-2CD2332-I model. All cameras are running a modified 5.1.0 build 140218 firmware by Mazi. As you probably know that firmware version has a backdoor (even if it is a modified one). I'm trying to upgrade my cameras to the newest possible version however I'm a little bit stuck. My main issue is that Mazi Security website has only 5.4.5 build 170123 listed and the upgrade straight to this version fails immediately. I have tried to contact Mazi support however they completely ignore my requests. Using web.archive.org I've managed to find 5.3.0 build 171012 on their historical website however upgrade straight to that version fails too. I suspect that I need to get 5.2.0 version first and do the upgrade in the following order 5.1.0 -> 5.2.0 -> 5.3.0 -> 5.4.5.
From your experience with Hikvision firmware does anyone know if it is possible to force the upgrade from 5.1.0 to 5.3.0? If not, what are my options? Do you think upgrade from Mazi's 5.1.0 to Hikvision's 5.2.0 and then to Mazi's 5.3.0 firmware will work?
Any advice is appreciated.
