Hi Folks,
Are there any specific guidelines on how long you can run a HDMI cable to view feeds from a downstairs comms rack to upstairs tv location, and if so any specific type of cable to use for HDMI?
Basically just trying to work out what cable i go with to be able to view the camera feed from TV on the upstairs room.
would running cat6a cable be better than HDMI to future-proof and use media converter on both ends to connect NVR to an upstairs TV?
distance would be close to 12-15mt.
Appreciate your advice.
Thank you
Thank you
