Mark moving persons.
maybe we're talking past each other? what I would really just like is for the movement in the image to be marked with a square, as in this video. So like in this video around the person.
Yes, I call those bounding boxes. teal for humans yellow for vehicles. Those are POTENTIAL targets.
They will change color when IVS Activates when they cross line for instance. Flash red momentarily
We aren't talking past each other.
But you need that icon in the lower left to turn that feature on.
How to enable native Internet Explorer in Windows 10 and 11:
Open Notepad:
Copy then paste the single line of code below into Notepad:
CreateObject("InternetExplorer.Application").Visible=true
Save as OpenIE.vbs
Make sure the the file name ends in .vbs not .txt, If it ends in .txt you must rename to .vbs
Create a shortcut to the above file and double-click it anytime you want native Internet Explorer.
Open Notepad:
Save as OpenIE.vbs
Haliluja, it worked. Thank you for the tip with IE. Unfortunately, the rewrite is still only displayed there. The border is not transferred to Synology either. So it's cool that it works. I don't know what I'm going to do with it yet.
Glad you got it going.
Yep, as I said, it only works in Dahua products and does not transfer to 3rd party.
And as big bigredfish said, all those lines and boxes can get annoying quick.
It is good for setting up the camera and troubleshooting, but not real useful for daily viewing.
