T Teeling611 Pulling my weight Dec 29, 2022 144 101 USA Jan 4, 2023 #1 Anyone know anything about this company or its cameras? Will they work with BI? Found some used ones for about $30 each. Thanks
L ludshed Getting comfortable Sep 14, 2022 649 822 Us Jan 4, 2023 #2 All the Walmarts in the Midwest use their dvrs and cams. Reactions: Teeling611
Mike A. Known around here May 6, 2017 4,209 7,092 Jan 4, 2023 #3 Datasheet says they support ONVIF so probably so at least at some basic level. Depends how you're using them but I'd avoid dome cams unless maybe if indoors.
T Teeling611 Pulling my weight Dec 29, 2022 144 101 USA Jan 4, 2023 #4 Mike A. said: Datasheet says they support ONVIF so probably so at least at some basic level. Depends how you're using them but I'd avoid dome cams unless maybe if indoors. Click to expand... Thanks they are indoor only 2mb.
