Many cores or greater speed, which is more important?
Sparkey
Getting comfortable
Apr 3, 2015
329
272
The United States of Gawgia
I currently have BI running on a server with a i7 4790 cpu running at 3.6GHz and 16GB of ram. 11 cams.
I have available a dual processor server running 2 E5 2620's running at 2.00GHz. 24 cores total. 64GB of ram. I also have a couple of E5 2670's available I could drop in which would boost it up to 32 cores and 2.6GHz.
I plan to add a couple more cams so would it be worthwhile to transfer BI to the second server even tho the cpu speed is lower?
TIA
TIA
Hi @Sparkey
There's more than Hz or cores to this evaluation .. you need to see how well the cpus support H264/H265 encoding for example ..
In general, newer generations of chips = better ..
What is your current CPU%?
If you have done every optimization in the wiki (substreams and direct to disc is a must), then your CPU should be sub 10% and no real reason then to update for the sake of updating...
A member here runs that same processor with 50 cams at sub 30% CPU.
i5-4590 @ 3.3GHz, 16GB RAM, onboard video running 34 cams fine at 70-85% CPU usage. ~20,700kB/s 250 MP/s.
Your system is stronger than mine. I've tried optimizing up the ying yang and have just accepted my CPU usage.
Reactions: Sparkey
i5-6500 3.2 16GB memory but running @ 1.30 in general with 6 camera's. I think that's pretty efficient.
