After I realised the limitations of my initial purchase of an unmanaged 8 port POE switch ( TP-Link TL-SG1008PE), I bought a 16 port, 8 POE + 8 (TL-SG1016PE). The background to the new purchase was the issue of me dealing with the camera subnet which my 8 camera Hikvision NVR system imposes, and which interferes with the ability to directly manage and configure cameras with ONVIF or Dahua etc software. The TL-SG1016PE offers me greater flexibility to access the cameras' subnet, to experiment later with an alternative connected BI PC system. Incidentally a couple of planned PTZ cameras are likely to be powered directly, ie not via POE.
The TL-SG1016PE has Easy Smart, management via a web GUI and a Configuration Utility. As far as I see an unmanaged 16 port switch 8 POE+8 will fit my requirements. So are there any advantages in being able to use any features of TP-Link's Easy Smart features?
The TL-SG1016PE has been powered up and working,
What are the advantages of having QoS, VLAN, IGMP Snooping features, the network switch will be on Hikvision NVR's subnet anyway. Easy Smart's cable test feature I sort of can appreciate.
Any advantage with having a switch with TP-Link's Easy Smart feature?
