Making a more secure door frame from kick in attacks
mat200
17,426
29,389
Not exactly sure I follow.
Assuming the keyway is on the side of the door you are trying to prevent entry from, then this makes no sense... You are going to be kicking the door from the hinged side, essentially forcing it closed. This also puts their reinforcement plate on the wrong side of the force being exerted. If anything you would want to make sure you have an adequate door stop around the entire perimeter of the door jamb (which I didn't see at all?). Also, you would want to run MUCH longer screws for the strike plates.
Perhaps it's what you don't want to get out ??
Reactions: Keizer
^ I have one of these on our front door. THIS is what I am thinking about at some point...
Reactions: mat200 and CanCuba
