- Dec 24, 2016
- 410
- 320
currently going through the exact same thing with scumbags...got a locking box but they are crow-barring a whole row of 4 boxes, even in broad daylight...Super Bowl day morning they got us!....gonna maybe upgrade all to that Epoch mailbox on Amazon..would be great to get this sensor installed inside
the box...has anyone hooked it up wirelessly?....I already have a lot of homekit, Hue bulbs, Wemo stuff, Lutron Caseta lights, Alexa stuff...didn't really wanna add Smartthings to this mess...any way
to incorporate one of these sensor devices to my existing myriad of hubs?...would ideally like the sensor to trigger Blueiris when the box is opened, and my PTZ 49225 zooms right in on them...what do you think?
The problem you'll run into with putting a wireless sensor inside the metal mailbox is its going to block the sensor signal. I had that problem when I wired up my mailbox sensor.
Do you have a means of getting sensor inputs into Blue Iris (ie using one of the serial inputs they recommend)? If so, then any kind of sensor you could wire up to that would work well. Sounds like it would be a perfect use for a PTZ camera. Have it zoom right into the box in that instance.
I ended up installing a MailBox mailbox: http://a.co/idF8e4O
Its quite heavy weight. Not as overkill as the Fort Knox mailbox, but it looks like it should be a lot more resistant to prying open than the average Home Depot box.
I kept the door sensor on the mailbox, except I have it set up to tell me when the mail slot opens and mail is delivered. I am not monitoring the locked door, so I guess someone could pry that and I wouldn't know.
