My alarm company is trying to convince me to
replace my DSC PC,832 with a Lynx 5100 panel with a
GSM cellular as the means to connect to the
monitoring center. I'm quite happy with my system
except that is uses the telephone line which can be
easily cut by a would be intruder. The Lynx panel
allows me to control my system (turn ON or OFF)
via the internet using the Honeywell app for my
iphone and it gives me a status of any open doors or
window. But that upgrade will come with some cost
I'm Just starting to search other options while
salvaging my existing system. I see that DSC sells a
Internet communicator. Can anyone enlighten me on
a PC1832 setup with a Internet communicator and if
there is any parallel features like the Lynx 5100 panel?
Mahalo.
CJ
Mahalo.
CJ
