Hi,
Model: LTN8964-R
56 IP Cameras
37TB Total Capacity
My NVR has been working fine for 4 years now. This week I go to playback footage from the app and I get error 8200. I needed the footage asap so I go straight to the NVR. It is extremely sluggish and I can’t access the playback menu at all.
I try a hard reboot. No luck. I try to export the footage from the export tab for a 1 minute period. It takes over 5 minutes and then crashes. I boot up and check the HDD status and HDD1 says repairing.
Should I assume that HDD1 has failed? How do I identify the HDD causing the issues?
Model: LTN8964-R
56 IP Cameras
37TB Total Capacity
