- Apr 18, 2016
- 213
- 145
I have a DS-2CD2032-I 12mm and was wondering if it could be used for LPR from 90-100 ft. Camera would be located under a 2nd story eve and camera angle is less than15°. What do you think?
Hi CRC,
From what I have been reading you should be mounting the camera lower to get a better angle on the car.
Is the street sloping upwards to your house? If so the angle maybe different....
To @mat200 's point, yes. Mounting to the corner of the house at that first level roofline would be better.
For reference that first video the camera is mounted at 10' and the second one at almost 15' above the capture point.
So a lot will depend on the camera and lens. Perhaps you can get by with the second story mount, but I'd temp mount it in each location for a few days and see what works best.
I'm partial to the #2 shot, be right over to help you cut that palm out of the way
I'm not sure but many of my neighbors have built brick "structures" as can be seen in a couple photos above..As I was responding I just realized why you asked; hide a camera in the mailbox stand? I'll have to think about that a little.Hi, I see you have mail boxes on the sidewalk... how large of a box are you allowed to put there ;-)
I've done a little more research on other cameras for my application and the IPC-HFW5231E-Z12 seems like it would work. At $218 price seems ok, any other recommendations?
