Can anybody share their LPR motion settings? I have absolutley had it and threw my hands up and set one of my LPRs to continous recording and will probably do the same for the other 3. I have it as sensitive as possible and still miss events.
First, I assume constant "signal restored" messages in the status are normal at night when its just a black image feed because the bitrate is so low right?
I've had motion size and contrast sliders fully left (most sensitive), 0 sec make time, not required to travel pixels, dissabled the trigger reset if exceeds certain frame %, simple algorithm, high definition (tried regular too). I cant get it, I can take the darkest late model car (LED tail lights that dont show up) and it can trigger the camera, but then tonight I watched a POS neon with regular bright incandescent lights drivr right out and not trigger the camera. I'm at my witts end
They are dahua 2 MP starlight Z12 cams. I have it set to the Dahua profile that has ONIF in the description, 25 FPS, i frame the same, direct to disk, etc.
Tonight I changed it to 15 FPS and continous recording. Until I can get the motion working reliably. Thanks for any help.
Sent from my VS990 using Tapatalk
