LPR HFW5241E-Z12E enclosure ideas?
tomas21
Aug 12, 2014
179
24
US
Picked up a HFW5241E-Z12E and looking to install inside some type of enclosure... curious what solutions folks have come up with for this camera.
Bird house, faux rocks, etc.... going to be looking at a couple locations to install mine. Bird house on fence post, rock, etc
Try these -
Mailbox
Utility hide
I built a box to hold two cams. I is in my garden behind a pine tree. It just went functional on Tuesday and I still have some slight tweaking of the exact positions of the cams within the box. But they are mostly where I want them.
Here are some shots from the cams
InkedLPR-E.20201029_113804371_1_LI.jpgInkedLPR-E.20201029_203348599_2_LI.jpgInkedLPR-W.20201029_125712150_1_LI.jpgInkedLPR-W.20201029_193953612_1_LI.jpg
Nice.. i think i'm going to get some T&G and make some customer bird house to attach on Fence line.. looks like you used some type of t&g
^^^ These are the ones that got me to thinking about a box!
View attachment 73754View attachment 73812View attachment 73756View attachment 73757
View attachment 73758View attachment 73759View attachment 73760View attachment 73761
I really like what you did here. I do feel the urge to add a suggestion... (especially since it is at ground level) the warmth of the cams is going to pretty much guarantee that you'll have critters making this a nest box really soon. I would suggest doing everything possible to seal the box up tight. And toss a few mothballs inside for good measure!
Reactions: looney2ns
I have put holes in the bottom to drain any water that gets in. I also have two vent holes at the top sides. I have covered them with screening. Once the cams are secured in their final resting place, I will put weather-stripping around their access holes. Good idea about the moth balls.
Reactions: sebastiantombs
Yeah, I take credit for the idea ;) but my buddy who owns the place built the enclosure
I think for my solution a bird house with cam positioned to view plates is going to be ideal.. thx for the ideas. Was looking at prefab bird houses on Amazon but may just mockup own to ensure size of cam etc fits perfect.
Going to start looking for Birdhouse designs and materials at HD to ensure weather proof, moth balls etc :)
What kind of prep and paint did you use on this enclosure?
The wood shutters and columns on the porch are rough wood in a brown. I chose the color based on the best match to that color using a brochure from Home Depot. So I had the brown paint mixed and used a latex white primer.
