@TheGooginator - what are your night settings (same as day?). We can clean that pic up some. Send screenshots of your night settings.
Here are my settings for night mode I didn't touch the picture settings. WB is set to Auto.
OK - you can speed up shutter to 1/2000 and probably knock HLC down to 30-40 and Gain to 35. That should knock most of that headlight glare out of there.
You might be able to nudge the camera down a little too - those plates were near the bottom of the image - is there enough space below that if someone had a low plate hanging off the bumper you would still get?
Are those headlights or tail lights?
You may have to position it so you get them leaving only to avoid the headlight washout.
I'm surprised that plate was brighter being hit with IR. You are running a 1/1500 or 1/2000 shutter right?
As long as you are getting good reads on the back of most of the cars (those that don't drive on the wrong side of the road that is) I'd say that is successful.
I would try your settings from yesterday anda bit, iris will greatly effect the amount of light...
.....assuming you have IR at 100%
And you’ll be able to get this dialed in in a day or two if you park your car there and have someone help vs waiting on the random vehicle, it could take weeks
Do you own a car?
Alright I went back to 1/2000 shutter my gain is now 10-40 and I increased my Iris to 53 and moved my HLC back to 40. Lets see how those settings work out tonight. Good this is this car comes every day at around the same time and I recently verified it is the newspaper delivery guy for those to still get those haha.
