- Jul 24, 2015
- 229
- 24
Hikvision might do a cheaper/better one. https://s.taobao.com/search?q=DS-2C...all:1&initiative_id=staobaoz_20160128&ie=utf8
http://www1.hikvision.com/cn/prlb_1008.html 4k bullets and domes can be chosen on left side menu.
Be warned though, these Hikvisions will be Chinese only unless you find one with '多语言' which means multi language. Some of the sellers will agree with install other languages for an extra fee.
One thing I notice on the Hiks is that they seem to be limited to an incredibly small bit rate cap.
The Dahua 30fps has a limit of 96Mbps bitrate and the comparable Hiks have only a 16Mbps bitrate. I wonder if that could be a mistake. Seems so low. I keep my 3MP Hiks at close to 11 Mbps in 1080p. You'd think with 4 times the resolution, the bitrate ceiling should be raised on the Hiks. Doesn't that seem a little low? Strange.
4K Hikvision DS-2CD40C5F
32Kbps ~ 16Mbps
http://overseas.hikvision.com/en/Products_accessries_509_i5579.html
4K Dahua IPC-HF81200e
32Kbps ~ 96Mbps
http://www.cctv-mall.com/dahua-ipc-...hua-ipc-hf81200e-12mp-ultra-hd-network-camera
