- Oct 30, 2014
- 21
- 3
I have had BI registered for one camera for a few weeks now. I only have one wireless Zmodo 720p camera. I started by a higher FPS rate (30fps) on both the camera and the BI software. I had many "no signal" errors. So I dropped the FPS to 15fps on both camera and BI. It worked better for a week. Then BI kept giving me the dreaded "no signal" and I could not get it to connect. The camera was always online.
Finally, I thought maybe too many FPS were causing a connection problem, so on both camera and BI I set it to 10fps. Worked awesome for a few weeks, when the signal dropped, BI watchdog would reconnect shortly after.
Now I am at 10fps, and I am getting frequent "no signal" errors...for two days now! I just won't stay connected. My camera video is set to "good" quality. It seems I can only get BI to pick up the signal if I log into my camera and refresh the settings.
One other thing I noticed is the camera is set to use software encoding...
Can anyone give me tips on what to do next?
I am only running one wireless camera, my CPU percentage is at 8% or so...
Thanks.
Thanks.
