Hi all, first time poster here.
I have a strange issue come up when my IP camera server PC is left dormant (ie., Windows is locked and PC is left dormant for 30mins or so) - Frame rate in UI3 streams and (triggered) recordings drop to 0-3FPS and CPU utilization drops to 2-6%. If I walk up to the PC and log in, about 30 seconds later frame rates come back up to 10 FPS and CPU utilization goes back up to 11-17% (this results in smooth playback and recording... but as mentioned, drops again soon after I walk away from the PC)
My set up:
- NVR server: Windows 10 laptop with i5-4300u CPU w/ QuickSync.
- 4gb of ram
- Blue Iris 4
- 2 x GW5089MIP Cameras
- Cameras and Server on common switch (unmanaged)
- Recording Direct-To-Disk at 2688x1520resolution, 10fps, 5000kbps VBR, Frame Interval=20, H264.
I thought of adjusting the Minimum CPU utilization from the default 5% to 20% in Windows power management, but this didn't work. I also set 'Turn off hard drive" to Never but this didn't help either.
Thank you in advance for your advice.
PS, I attached a screenshot of the UI3 interface while observe this strange behaviour (a little clock symbol appears sometimes in the top right corner).
Matt
My set up:
- 4gb of ram
- Blue Iris 4
Matt
