- Jul 11, 2016
- 18
- 4
Looking to put a low cost camera system together but with better quality than most store bought units.
I usually use IPC-HDW5231R-Z for all known reasons, but the price would be too high for a budget system. Would probably only use them outside. Was looking at the HDW4433C-A on Amazon and they are $63 which would satisfy a budget system I think. Having said that, a refurbished dell and BlueIris would be ideal, don't think a Dahua NVR would be any better, then again, maybe? Dell with i5-3570, 8gb ram, 120gb ssd, 2tb WD Purple is about $350, $65 for 9 port POE switch, $70 Cat5e, 8 of the HDW4433C-A for $504. So $1050 for a IP camera system with BI license.
Aside from IP, I know decent 2mp CVI/TVI cameras sell for about the same price as the abovve mentioned camera. 1000' RG59 siamese is $170. Aside form that I don't know what a decent DVR costs. Are you better off buying one of these systems as a bundle or putting one together as well? From what I keep looking at the price would be in the same ball bark as the above system using a Dahua NVR, same 2tb drive, after BNC fittings and a power supply.
Are their better alternatives even in kits that beat the crappy store bought stuff? Thanks guys.
