Good morning guys, I would like to replace 3 wifi cams with 3 turret/eyeball POE cams
The cams are for indoor home use, just to see if everything is ok.
The Hikvision DS-2CD1343G2-I(UF) seem suitable to me because:
a) in terms of budget they are ok (under €100)
b) I'm interested in a 16:9 substream at 720p (whereas the Dahua lite in the same price range are still 576p in 4:3)
c) they seem to me to be WDR 120db, so even with the light coming in from the windows they should behave well
d) I use them at a maximum of 10 FPS so I'm not very demanding
e) 4MP is more than enough, since I'm now at 2MP
f) I know that in terms of night vision 2MP is better than 4MP, with the same sensor, but I think that 4MP can also be fine indoors at home, or not?
Ultimately, for my needs, could it be a suitable cam, or is there something better for the same budget?
PS: i did not find any review / test for this cam....
