- Sep 12, 2016
- 2
- 0
Hi,
New here, hoping for some help with my setup. Apologies for the long question(s).
I currently have 8 wifi IP Cameras around my house – six Foscam and two Wanscam - and using Blue Iris. I recently updated my network setup, and am having trouble getting everything working. I'd had everything running on a single wifi network, but sensed the cameras were slowing it down, so am trying to configure the IP cams on a sub-wifi network.
Previous setup:
I am trying to configure the setup below. I’m describing it as I currently have it, which is not working well. What do I need to do to make this work?
Questions:
I realize there’s a lot of questions here. I’m to the point where I’d be happy just to pay somebody to come for a few hours and fix my setup. Are there any services that do this? Anyway, any help with any of the questions above would be greatly appreciated.
Thanks!!
Previous setup:
- Arris Surfboard cable modem to Apple Time Capsule Wifi: “Network 1”
- All Cameras port forwarded on Time Capsule to no-ip.org domain
- BlueIris controlling/monitoring all 8 cameras through their no-ip.org addresses
- Also using a mobile app, IP Cam Viewer, to access cams remotely through no-ip.org addresses
- This setup was sucking up a ton of bandwidth because everything was going externally through no-ip.org, and it was all on Network 1, my main wifi network that I use for other media
- Same SurfBoard/Time Capsule setup initially for Network 1
- Powerline adapter (one of a few on Network 1) to an Asus wifi access point creating a new wifi: “Network 2”
- All cameras reconfigured to communicate on wifi via Network 2, (I currently have port forwarding only on the Time Capsule router on Network 1, but all cameras are working fine for my remote IP Cam Viewer so far)
- I’d like Blue Iris to connect to all the cameras only via their local IP address (192.168.x.x) on an internal network, ideally on Network 2 to conserve bandwidth on Network 1
- When I do this, the Blue Iris feeds cut in and out and nothing works smoothly – cameras frequently lose connection
- Note I'm using the same local IP addresses on Network 2 that I'd used on Network 1 - not sure why that kinda works
Questions:
- Should the computer that’s running Blue Iris be connected to Network 1 or Network 2?
- Do I need to set up port forwarding (or fixed IP or something) on the Time Capsule router (Network 1), the Asus router (Network 2), or both? If so, what should the configuration be?
- Does the Asus router need a fixed port/IP on the Time Capsule network?
- When I set a camera's local IP and port in the web config for each camera, is that its location on Network 1, Network 2, or both?
- I’d like to use the Blue Iris web server capabilities for remote access. Does this affect the configuration of Network 1 and Network 2? Could I then get rid of the no-ip.org setup?
- Has anyone had success using dropbox or another free online cloud backup service to synch the motion-triggered recordings from Blue Iris?
Thanks!!
