mat200
- Jan 17, 2017
- 16,194
- 27,157
Ok,
So time to go back to the basics:
Test with a known working port in the switch. ( remove other camera when doing this, to reduce the power load on the switch )
Test with a known working cable.
I've had switches go out - in unpredictable ways. ( smart green switch really did die in odd ways... power cycling brought it back to life... for awhile, then ports went off line randomly ).
I've had switch ports die.
cables die.
ethernet ports on PCs/ hosts die... rebooting helped sometimes, sometimes it was hardware.
others have seen rodents eat cables..
I've seen contractors cut cables... stuff them back pretending they're ok.
Numerous odd things do happen, so isolate it as best as possible ( another big reason why I always recomend N+1 cable pulls .. )
cables die.
