Lost Live Overlays
johnyfalco
Feb 16, 2017
8
3
Australia
Does anybody have any ideas why I have lost all my live overlays on all five cameras. They used to work but have all disappeared. Version 6.0.4.4
The date and time shows on my live feed for cameras, but when I view the mp4 the live overlay is not on the recording.
Are you using Direct-to-Disk recording? If so, when exporting to mp4 on the "Convert/export" menu, check the box for "Add text/graphic overlays from Direct-to-disk BVR."
This can be found in BI's built-in "Help" file.
Reactions: Bruce_H
I would suggest that you might want to consider using the timestamp that the actual camera provides, it makes it easier in my mind, then it is always on the video that is recorded, but perhaps you have other info than just the timestamp!
