I'd be surprised if it's not:
Code:rtsp:/username:password@Camera-IP:554/cam/realmonitor?channel=1&subtype=1
NOTE: two "/" after "rtsp:"
Thanks. I should have been more specific as I needed this for Blue Iris and was able to use "/cam/realmonitor?channel=1&subtype=1&unicast=true&proto=Onvif"
It leaves the sub profile blank when using the find/inspect for some reason. After manually entering it then it works fine. Thanks for your help.If I had known about BI (I use BI) or you'd posted in the BI forum, I would have suggested you put in the cam's IP, username & password and click on "Find/Inspect" button; BI would have very likely configured it properly for you.
Glad you're up and running!![]()
What version are you on?
While BI does leave it blank, recent updates have the substream as a pulldown.
