I'm having an issue with a Lorex camera setup that I'm curious if anyone else has run into. With the NVR system I have you can pull up the NVR via IP address from a PC to get to the settings of the NVR and then from a section called settings you can see all the IP cameras and there's a button there to press called browse camera that allows you to login directly to each camera to do further configuration. I have one camera that shows up fine but when I try to browse to that page it won't even load the cameras webpage. There's not a reset button on the camera that I can see so I've unplugged it (POE) and left it for 1hour and then plugged it back in. It comes back online and the picture shows but still I can't login to it like I can with all the rest.
Any one run into this and have a solution?
Thanks much,
Thanks much,
