Hello,
I have recently purchased Lorex NR916X-N NVR 16-channel system. When I received the system, I plugged all the cameras in nvr slot, nvr is connected to router, using upnp (default setting, just changed date and time). All the cameras are working except 2 case, Case 1: after plugging all cameras to nvr slot, 2 of the camera did not display video but displayed "ip address" and message "Invalid username or password". Case 2: i tried to swap 3 channels by removing Ethernet port from nvr slots and swapping them, then it displayed same message on 3 channel I swapped, i tried to swap them back to what they were before but that did not work either.
I tried resetting password and applying it to all channels but that did not work either. Please ask if you need more information. Any solutions or suggestion? Thank you for your time and help.
Thank you
Thank you
