I can not seem to find any info pertaining to the use of the *Camera Image Settings >> Config File.
In the Drop-Down there is - Normal (Default), Day, Night.
Assuming the options are there to use any one of the three, as chosen, I'm also going to assume that the specific file (day) can be used for a specific length of time for the course of a day, then switched to the night config file settings at a given (set) time?
I hope I'm making sense.
My assuming again.
Say for example I choose the "night" config file at Dusk. I tweak the per-camera settings to optimal for that particular camera, and so-on for each.
Does the camera settings config file automatically get backed up for use later, at a set time? If so, where?
The same question is asked for daytime camera settings.
I do not see any options to "save" the configuration. Night/Day, to have the settings automatically come into play on a day-to-day routine. Is this possible.
I'm new to the NVR World. Bare with me, please.
EDIT TO ADD IMAGE
Would this info be relevant to my system? = Tested by me = NO
My assuming again.
EDIT TO ADD IMAGE
