I am new to the forum and did not see a post about these two camera models (Lorex LNB9232 and LNB9272). For better or worse, I am going with a Lorex system (along with a couple Dahua Starlight cameras from Andy) for my property and wanted a mix of varifocal and fixed lens cameras. What I did not consider was the drastic size difference between the two (currently) high end Lorex camera models. These pictures are an attempt to show the size difference and to highlight that the fixed lens (LNB9232) will work with Andy's PFA130-E junction box but the varifocal (LNB9272) will not. I have not ordered the Lorex brand junction box yet to determine if it will fit the varifocal.
The size and weight difference between the two is much more drastic than I had anticipated. Hopefully this assists someone in their decision making process. For size comparison I included one of Andy's IPC-HDBW4231F-E2-M 2.8mm dual cameras (I don't have a Dahua bullet for comparison). With Christmas around the corner I will not be installing them immediately but once everything is up and running I will post some screenshots and images. I wanted 4K cameras that could do 30FPS (taking into consideration that the storage space for such footage quality is quite expansive/expensive).
Would someone please provide a good link to purchase 200+ft of CAT6 direct burial cable? I have heard good things about Vericom MBW6U-03676 but before I go running it through my PVC conduit I would appreciate some honest feedback. For my interior runs I will be using the Monoprice cable that has been previously linked on this forum.
The exact model numbers of the cameras are LNB9232S-C and LNB9272S-C
Thanks in advance.
Thanks in advance.
