Lorex has released firmware in which motion detection works properly and is ONVIF. The Dahua firmware is worse than the new Lorex firmware, so I want to change it
Now I will describe the problem from the beginning.
I uploaded the Dahua firmware to Lorex cameras via TFTP, but motion detection does not work well. Now I tried to upload the latest Lorex firmware to these cameras again, but unfortunately it is not possible. I do not know if I did something wrong. I am attaching the firmware files and command files. The current firmware version in the camera is:
DH_IPC-HX5X3X-Rhea_MultiLang_NP_Stream3_V2.800.0000018.0.R.210707.bin I also tried updating from the browser, logging in to the camera, but unfortunately it is not possible.
run dr
run dk
run du
run dw
run dp
run dc
tftp 0x2000000 pd-x.squashfs.img; flwrite
tftp 0x2000000 .FLASHING_DONE_STOP_TFTP_NOW
sleep 5
run dr
run dk
run du
run dw
run dp
run dc
sleep 5
