By the great advice of this forum, I purchased 4 x IPC-HDW5231R-ZE cameras about 2.5 years ago and mounted them perfectly to cover the areas I need covered. (All mounts are less than 7 feet from the ground).
Now I am looking to upgrade a few of the cameras. Specifically, I'd like to be able to have reach to 100-150 feet with full quality during daylight.
Low-light quality isn't as important because all of my outdoor floodlights are on smart switches and I'm working on having Home Assistant turn on the lights based on motion detected from the cameras. Each flood light mount holds 2 bulbs that are 3,000 lumens each and lights up my camera coverage area quite well.
I also inherited a NAS from work with 32 TB of usable space in a RAID5, which I plan to dedicate solely to the video stream, so space isn't really an issue.
With that all being said, what is considered the latest and greatest for 2021? I'm OK spending up to $500 or so per camera.
Also, given the mounts I already mounted to the house, I'd prefer to stick with Dahua and turret-style cameras if at all possible. However, I'm not against re-doing the setup if there's a better product on the market.
Thanks in advance!
Thanks in advance!
