- Dec 3, 2015
- 50
- 5
I need (or want
) to add up to another two cameras to my Hikvision 7604NI-E1-4P NVR. I've got a 2532IWS 2.8mm 3MP using POE - which isn't that good for night time use for where I originally bought it for - it isn't the end of the world and I've worked out where I can put up to another 2 and then use the 2532 for another location.
I prefer the dome camera as they'll be mounted on the soffits. The front garden is fairly dark and there are no street lights, however I have LED security floodlights already installed. The only thing that may be a concern is that when cars pull up into my cul de sac that the headlights will white out the camera picture.
I've been looking at the 2142 and 2342. My NVR has a 3TB HD. I presume that 4MP will be fine to use but for the life of me I can't work out which ones to get next? Or where in the UK to get them from as the last place I used where next to useless with there after sales service when I was having a blonde moment setting up the first bits of kit I bought.
