Trying to figure out some solutions to allow me to split my single cat5e supplying power to cams that can be split to both provide power to cams + a 12v accessory if possible.... looking for input.
Use case 1: Frontyard PTZ + external mic (12v)
Use case 2: Pool PTZ + IR light (12v)
- PTZ: Dahua PTZ425DB-AT
- Power Consumption: Basic: 9.5 W / Max.: 21.5 W (illuminator on + fan on + PTZ)
- Reference: EmpireTech PTZ425DB-AT 1/2.8"CMOS 4MP 25x Starlight IR 5mm–125mm Vari-
- Mic: M7WP-MIC Waterproof Outdoor Microphone
- Power needs: Supply voltage 8V-20V DC (recommended to use 12V, greater than 500 m recommended 15V)
- Supply current 17 mA
- Reference: Microseven IP Cameras
- Solutions: ?
- PTZ: Dahua DH-SD22204UE-GN
- Power: PoE(802.3af)
- Power Consumption: 5.5W
- Reference: https://www.dahuasecurity.com/asset/upload/uploads/soft/20201214/SD22204UE-GN_Datasheet_20201214.pdf
- IR Light: Tendelux DI20 IR Illuminator
- Power: consumes 20 Watts of power and requires a DC 12-24V input voltage. The package typically includes a 1.5 Amp power adapter suitable for the voltage range, such as a 100-240VAC to 24VDC adapter
- Reference: Tendelux DI20 IR Illuminator, 20W Infrared Floodlight for Security Cameras / License Plate Recognition
- Solutions: ?
