Looking for NVR recommendation to replace Q-See 8-Channel
jgfii
May 7, 2017
4
1
I currently have a Q-See packaged system that includes a QCK81-8HF-2 NVR with 8 QCN8093B-N cameras. I want to replace the NVR with a model from Dahua, LTS, or Hikvision and would like a recommendation on which model to go with. Will I be able to use the Q-See cameras with any of these NVR brands or will I most likely also need to replace the cameras?
Your NVR is likely a Dahua OEM, so another Dahua or OEM would be the best bet. Or if you are looking to replace just to get access, follow one of the the threads above and save your money!
