No problem...be safe.. thank youGoing through a power outage at the moment so will help us I can once powers restored
lol..f45oah....a land owner! IPCT folks love people like you with big Ford 3500's dualy's
Is it possible to run 4 x Cat6 cable out to the road entrance with that sign? I could see a camera pointing left...and camera pointing right down the highways road to alert you of oncoming vehicles/persons from 100' distant, a PIR, and a 24v LED light on those posts. Enough time for you to react appropriately.
If not the road...what of running some cable to that center island with the tree infront of the house? Heck... I would do both road sign & posts...and center island.
my quickie 3d paint markup:
the traffic is very constant on the highway...i like your thinking... think it will give tons of false alerts... i can run anything anywhere here. just didnt know how long of a cat 6 i could runlol..f45o
No...if setup cameras & Blue Iris properly, you will maybe get 1 out of 200 false alerts. AI has come a LOOOONG way.the traffic is very constant on the highway...i like your thinking... think it will give tons of false alerts... i can run anything anywhere here. just didnt know how long of a cat 6 i could run
This is great.No...if setup cameras & Blue Iris properly, you will maybe get 1 out of 200 false alerts. AI has come a LOOOONG way.
Forum search topics you need to read up on:
how to trench cable (either Cat6 or Fiber or Point To Point dish like Ubiquiti)
how to use spotter camera with PTZ
license plate camera setup and which model camera is best
IVS tripwires and intrusion boxes.
DORI (distance relative to camera lens to identify a face)
outdoor lighting. 24v or 110vac
Home Automation: i favor Home Assitant as it's free and tons of support. There is also HomeSeer and others you can choose from.
a.) MQTT broker
b.) Z-wave or Wifi equipment (I went Z-wave as much as possible)
c.) smart TV interfacing
d.) alarm system interfacing
e.) As I mentioned, the Dahua AI cameras I have infront of my house along with a SD4 series PTZ: if a HUMAN triggers an alert 150' down my driveway, the camera notifies Blue Iris which activates the PTZ to move to a preset and start to auto-track that HUMAN with it's 25x optical lens. Blue Iris also notifies my Home Assistant (via MQTT which you will learn about) to turn on my smart tv, switch to tv source 2 which I have a Rasberry Pi2 hooked to that is 24/7 running the UI3 program. Home Assitant also activates a in-house buzzer. All this happens within 2-3 seconds. Gives me time to investigate & react.
f.) I use a DSC Powerseries 1864 (I think that is the #) which also interfaces with Home Assitant. In addition to the cameras, my just-in-case-backup is using 4 outdoor Bosch pet-friendly PIR's. If those PIR's are trip, the DSC notifies Home Assistant and the smart tv comes on with UI3.
As you can see...with Blue Iris and Home Assistant, soooooooo many doors open. It was VERY important to me to have time to react to a situation on the fly, not 4-6 hours later.
all that research is just for starters![]()
So now that you see you need a multiple purposed cameras the original question remains. Do you have a budget in mind. These cameras I speak of are between $150 to $200 each for static cameras. The PTZ cameras are three or four times that cost depending on the model you pursue. So if you're looking for a $200 setup I have no advice for you and someone else will have to jump in. If you're okay with two or $3,000 total you're on the right trackThis is great.
