Hello.
I need some not too expensive (below $100) IP camera module (w/o lens)
Main requirements are:
1. Low noise
2. No ActiveX (IE mode)
3. No spatial/temporal image processing
4. 1080p @ 30fps (60fps preferrable, if available within price range)
5. Ability to adjust shutter speed
I need these modules for some technology process control, so less image blur is required. The issue with modern modules is that all of them have some kind of noise reduction built-in, and in most cases it can't be turned off! And since there will be a lot of small and precise movement in the video, it all gets smeared/eaten away by NR. So, currently I'm forced to use some very old (2012 year) 1.3mp model, which have low sensitivity and lot of noise, but they don't have any kind of noise processing so delivered image is sharp and not blurred by motion.
Thanks in advance!
1. Low noise
Thanks in advance!
