Hello all,
I am looking for what might be compatible with blueiris for home security. Such as window and door open close sensors, weather / temperature, fire / smoke detection etc....
Basically I am looking for something that has a wall mount head unit that can also integrate with BI.
I have called dozens of home security companies and come to this conclusion.
They are all ripping everyone off with their outrageous install fees and monthly monitoring cost, just to install something that is all wireless and only requires a screwdriver to install.
Due to my location I only have internet and no landline so most companies will not even install without a land line or a cell add on to the system that will not even get LTE service anyway.
I am looking to install the system myself and hopefully have something that integrates with BlueIris.
BlueIris Specs
Intel Core i7 3770
Ivy Bridge
MSI Z77A-G45 Thunderbolt (MS-7752) Motherboard
16GB ddr3 memory
10 PoE IP cams running at mostly 720.
CPU typically hovers around 20 - 24%
Storage is attached 40tb Synology ds918+ NAS.
The system is headless as I remote into it as needed.
I have a 24/7 Raspberry PI mounted to a security monitor running the web browser view 24/7.
Remote access to the blue iris is over Openvpn secure tunnel using the android apps.
BlueIris Specs
Intel Core i7 3770
Ivy Bridge
16GB ddr3 memory
