HI all,
I've been using an Amcrest AD410 wifi door bell connected to by Synology Surveillance Station for about two years. I have it configured with the Dahua DMSS app via a forwarded port because I found it worked better than the Amcrest app. Right now, the AD410 is failing - when the button is pushed, it reboots. I have read of battery issues and really don't want to get in to replacing the battery, just looking for something new.
The following would be my minimum requirements:
Can you provide some recommendations for what's out there now as a start for me to begin looking at options?
Thanks!
- wifi
- Connects to external mechanical chime.
- Ability to interface with Surveillance Station. Ideally it could do everything through SS - notifications, intercom, etc., without needing an external app. The Amcrest was always very clumsy with SS, and I don't recall if that was the camera or SS itself. If not SS, needs to have a clean app of its own - one that will allow me to respond to a call quickly.
- Doorbell notification is critical, two-way intercom is secondary. I haven't used the intercom that much, but the doorbell notification to my phone has been helpful to have.
- Does good with morning sun - the Amcrest has not had an issue that I can tell, but it may be part of the reason for the recent battery failure. House faces east and there is no covering over my porch.
Thanks!
