Plan on upgrading some older cameras I have, but with so many choices it's hard for me to know which way to go.
List of some of my current cameras:
Edit: looking further i wonder if the IPC-T54IR-ZE S3 is the way to go. Appears to be an upgraded version of the IPC-T5442T-ZE
- Driveway - Dahua - IPC-HDW5231R-ZE
- Driveway is about 30' wide. It's an OK camera, but I feel like it's dated and not as clear as I would like. Plan on moving this camera to inside my 2 car garage (to retire a really old Hikvision)
- I currently have a IPC-T5442T-ZE (purchased in 2022) setup for my front bedroom area that works great. Not sure if this is still a good camera to upgrade for the driveway or if there are better options.
- I have 2 bullet cameras that are in my 45' long shop that are from 2016. While they work being inside, they are a bit fuzzy if the video is enlarged.
- For these I was thinking of going with IPC-B54IR-ASE S3
- Also need a new camera for my backyard that will be looking from the back corner under my patio cover to the rest of my backyard. Again, not sure if the IPC-T5442T-ZE would be to the go to for this or not.
