Hi there, I would like to replace an existing camera I use to monitor my living room, because the current one (an AXIS M1054) doesn't have the night view.
Specs are quite simple ....
- possibly in Dahua (but other brands are also ok)
- Needs to be placed on the top of a kitchen locket
- Needs to have quite good picture quality
- Needs to have a I/O port (my alarm system triggers the calera for recording on a Synology NAS)
- Needs to have a night view (in the dark)
My actual Axis camera specs are the following :
- Image sensor 1/4” progressive scan RGB CMOS
- Lens 2.8 mm, Horizontal field of view: 84°, F2.0, fixed iris, fixed focus
- Light sensitivity 1.2-100000 lux, F2.0
0 lux with illumination LED on
- Shutter time 1/25000 s to 1/6 s
- Pan/Tilt/Zoom Digital PTZ, preset positions, guard tour
- Video compression H.264 Baseline (MPEG-4 Part 10/AVC), Motion JPEG
- Resolutions 1280x800 to 160x90
and its current picture (area of monitoring) is the following :
Any suggestion or advise for a replacement of this axis camera would be welcome !!
I am not an expert so to be honest I choose the Axis for its look and not for its technical specs ...
The purpose is monitoring, I should be able to recognize someone on the picture and see what happens in the room at any time.
It will be connected to a Synology NAS.
Many thanks !!
Many thanks !!
