OK, this is the situation:
I have a motion detector that turns on several subtle pathway lights. They operate on main grid voltage. I would like to add an LED (flood?)light for a beam along the path, powered on grid voltage.
The distance it has to cover is about 8m (26ft) (and back).
Camera would be either a zoomed 5442T-ZE varifocal or a 3.6mm f=1.0 lens on 1/1.8" or 1/1.2" sensor. IR would not be used.
I don't want a "cuban solution", which attracts landing airplanes, local basketball teams and neighbors in rage.
So I need an estimate of the power I need for the cameras to work, but I don't want to be blinded either. 10W?
And I need to find international brands that build reliable lights, as my electrician is more expensive than the LED. I have seen many cheap ones on amazon with telling comments. (actually considered about getting one 10W for testing)
Any suggestions? Thanks!
