Hello. I have recently built out my network infrastructure but now i need a NVR/Camera system. Here is what im working with..
I have a TP link unmanaged switch with a port going into a 60W ubiquiti power injector. I have a cat6 coming out the injector up to the attic powering a ubiquiti flex switch. This gives me 4 POE+ ports to run cat6 to outdoor cameras i will mount to my soffits.
I want a system where i dont have to plug directly into the nvr ports for poe power. I want to plug them into my flex switch so i wont need such long runs all the way from the basement directly to the cams in the soffit. Ideally itd be cool to find a system where i can use a mix of outdoor cams on the network via my flex switch (but not directly plugged into the nvr) and indoor cams plugged directly into the NVR. Does a solution like this exist or is it all or nothing (ex all cams must plug into nvr poe ports)?
Id like a system w local storage (cloud option would be a nice bonus). I also want decent quality w night vision and motion push alerts.
I know this is a lot of info but do any cam systems come to mind that meet my requirements? Budget is roughly $500-1000 for the nvr and cams. Thanks in advance!
