When I am mobile I use a VoNets device to change my hot spot from Ipad or Cellphone into a wired connection.
It will work several modes, so make sure you plug into the Ethernet port and set it up for a bridge. That will allow it to
connect to the wireless and it will come out on the Ethernet port.
I have used this to check out networks while installing them. It works well from a MyFi pack to the vonets,
to a Ubiquity access point and I have WiFi inside the building.
I have even used this to finish turning up a server when the customer lost his internet.
