Looking for a decent PTZ for indoor. $300ish or less.
FlipNJ
Pulling my weight
May 3, 2016
366
134
Going down a rabbit hole and figured someone can recommend one. Tried a reolink trackmix and its garbage. Its for a basement, so its indoors but I need optical zoom. Nothing crazy since the objects to be monitored are only 10 feet from where the camera will be.
Tried asking Andy and haven't heard back yet. Budget is 200-300 dollars. TIA
FlipNJ , how much zoom do you need and is IR required. I have some older Dahua cameras similar to those that Chase mentioned. Are you looking for wifi or Poe?
