looking for 10 4k dome cameras + NVR package
tung256
Feb 3, 2017
127
31
i tried searching on amazon. seems the only package they have are bullet cams.
looks like i have to buy separately to mix and match. which system do you suggest i get?
need 10 dome cameras, 4k.
NVR capable of handling 2 8tb drives. outputs 4k off course.
thanks!
Are you using the domes at night outside, if so they will not work very well, there are a significant number of post of problems with dirt and IR and light reflections.
Go with a turret camera.
What do you want to do with the cameras? where will they be mounted ?
Why do you need 4k, 4K cameras are crap at night unless you have a lot of light.
If the cameras are outside and will be used at night go with ....
Use Dahua starlight cameras or Hikvision darkfighter cameras or ICPT Night eye cameras (https://store.ipcamtalk.com/) if you need good low light cameras.
I would go with a dahua system from andy. He is the goto dahua supplier for the forum. He has excellent service. Contact him via email [email protected]
He has two stores one on amazon and one on aliexpress. He has more products then on his stores.
Buy Products Online from China Wholesalers at Aliexpress.com
https://www.amazon.com/s?me=A2ZLH9E...ue&slotNum=0&slotNum=0&tag=ipctk-20&ref=as_at
Kingsecurity2018 @ Amazon.com:
5 of them outside, and 5 will be inside. I like the dome style just because they look discreet and slicker
i like to have 4k just to be safe and last for the next 5 years before something like 16k becomes standard...
Hi @tung256
Dome cameras can be problematic outdoors - suggest reviewing the topic here on the forum before making a commitment for dome cameras installed outdoors.
Do take a look at the cliff notes and various threads where members are sharing the knowledge and experience.
Reactions: MAK9876
Reactions: aristobrat
Agree domes look slicker - a few people here have bought the IPC-HDBW4231F for the front door
Other than that, the tag line on here (well placed) is domes suffer from deterioration, reflection etc....so that's the advice you'll get
I recommend doing a search of older posts and taking a look. Andy is a sponsor here on this forum and in the vendor list - send him an IM or post on his profile page @EMPIRETECANDY or his Ali/Amazon store
Reactions: VorlonFrog
