Hi there,
I've had the Logitech Alert system for quite a while. This is the one where the camera sends the signal over your homes power wires from two converter boxes which are on each end of the run.
I had the power supply side go bad and I thought I would have to junk the camera but on a hunch I used one of my PoE injector modules and the camera was detected by Blue Iris just fine.
However there is no password for the camera or any web page login screen built into the cameras firmware... or is there?
Blue Iris searched for the camera and detected only RTSP as you can see from the below copy/paste
Opening port 80...
HTTP request...
Failed with HTTP 12029
Opening port 8999...
HTTP 12029
Checking for common cameras...
Foscam FI86xx/98xx compatible?
Foscam FI89xx compatible?
Foscam FI9821 V2 compatible?
Foscam FI9821 media port compatible?
RTSP port open?
RTSP port detected!
Done
I am just curious if the homework has already been done on this and there are other ways to connect and modify the camera properties.
Looking at a question/answer on Amazon, I see the below response. Looks like the claim is it can be used as a PoE camera which is great! I just wanted to be able to enable more options. The Alert software is really nice actually but does not allow me to set up any sort of direct web access to the camera.
"Question:
Is this Camera PoE?
I use a little $20 PoE injector for my indoor camera. see less "
Opening port 80...
HTTP request...
HTTP 12029
RTSP port open?
RTSP port detected!
Done
"Question:
Is this Camera PoE?
Answer:
It is flexible and can use either PoE or the included Powerline module. PoE gives you a consistantly smoother video feed so you should consider that for a permanent installation. The Powerline module makes it possible to put the camera anywhere where there is an electrical outlet. With an extension cord the possibilities are endless. I use a little $20 PoE injector for my indoor camera. see less "
