Log: Exception: IP Camera Disconnect,
branxo
Oct 18, 2015
8
1
HI all, I have a DS-7104N-SN / P recorder with two ip cameras connected to the POE port:
new: ds-2cd2720f-i with firmware: 5.4.5 build 170123 and an older IP camera with older firmware that works perfectly and has no breaks.
New ds-2cd2720f-i has bugs: IP Camera Disconnect every couple of minutes. I'm crazy about it.I read on this forum that the new firmware 5.4.5 has problems with these interruptions so I add a ntp every 1 minute but no success, lots of network disconnection again ...IP camera have the latest firmware.
User from this forum: alastairstevenson had created a version of the IPC_R0_EN_STD_5.4.5_170123 firmware for R0 series that does not run this network checker program and put it on download: https://ipcamtalk.com/thread s/5-4-5-network-disconnected-exceptions.20280/page-2
Does anyone (maybe alastairstevenson, please :)) can do the same for the R2 series of cameras? thank you very much!
Reactions: Bink
OH that seems to have fixed it. I'm not sure whether it's the manual dial or, or I changed the camera resolution to 720P instead of 2688x1520.
***Just tested it, yes it appears to be a resource issue. The old NVR couldn't handle the higher resolution. Changing to 720P did the trick.
