Local URL Auto Login
Alexei
Oct 17, 2015
14
2
I used to use one for each of my 3 cameras from the "link to web" feature in smart pss but since updating my firmware this no longer works. Is this a new security feature?
Does anyone know of a local url auto login command
something like:
http://admin:[email protected]
Many thanks
I think using the RTSP you can put the user ID and password in the URL for auto-login type of deal.
Specific cameras can have variances in the RTSP URL syntax so you have to check it on the exact cameras you have. If you don't know it perhaps check the product documentation or maybe an ONVIF "sniffer" will find it for you.
