There are many, many camera makes and models which will determine its features. So that a forum member will more likely be able to help you I ask:
What is your camera's make and model?
Got it. Is one better that the other? I see lots of ivs setup so I assume it, but still just asking. Or is it a per application choiceBest practice is to use either SMD or IVS, not both.
Thanks. I’ll play with it and seeFor most people IVS is the better option, but it really comes down to your goals and field of view. In some instances SMD is a better choice.
