Loading Camera List Fail/Loading Timeline Busy
ingeborgdot
Pulling my weight
May 7, 2017
747
173
Scott City, KS
I went to Ui3 today and can't get in. It just keeps telling me these things Loading Camera List Fail/Loading Timeline Busy. I have never had this happen in all the years I have owned BI. What is wrong?
Is BI running on your PC?
Have you tried to reboot the BI PC?
Did BI update recently & what version of BI are you currently running?
Are you trying to access BI with UI3 from your local lan or from the internet?
A few details might be useful to make some suggestions as to the problem!
BI is running on a dedicated PC. I rebooted. I stopped service. I uninstalled and reinstalled. I updated BI, and then reinstalled older versions.
I am trying to access BI from Ui3 both local and remotely.
I can get into BI itself, but nothing from the Ui3 interface.
On my phone it pops up but everything is just gray.
What happens many times is a Windows update changes your BI server's LAN properties from private to public. Simply change it back to private and all is good in the world.
Hopefully that is your problem!
  • Love
Reactions: VorlonFrog
Sorry for the ignorance, how do I change the BI LAN properties from public to private?? Where do you mean?
It's not in BI, it's in Windows and is the network properties of the NIC (Ethernet or Wi-Fi card) that BI uses to connect to your LAN.
I went and checked the settings. It was on Private and not Public. I wish that would have been the case. It was not. Now I have to keep searching. I have stopped the service. I have uninstalled and reinstalled. I don't know what else to do????????????????????????????????
This is just one of 7 servers that I work with. This software has been running great on this site for over 4 years. Not any of the other servers have had problems.
1 week ago we got fiber and it worked great. Yesterday they changed our ip address like an IPS does. Today, this is happening with the problem. Coincidence?
Locally we use the local LAN ip of the server. That doesn't work. Remotely we have been using Tailscale. That doesn't work. So, I switched it to the new WAN ip address with port forward. That doesn't work. Nothing I have tried works today. Over 4 years of working and then one day, bam.
I'll venture that the new fiber modem's LAN/gateway IP is a completely different subnet from what the BI server was on before.
If so, log into the new fiber modem's webGUI and change its LAN to the same subnet as the BI server.
This system is the EXACT same system as another system I run. Same networking equipment, same cameras, same fiber, same everything. One has been working with this fiber for almost a year now. The other, was just hooked up a week ago. It worked fine for almost 6 days. Then today, not so much.
I found some info. There is no router other than mine in this fiber system. I have the same system at this site that I do at my home. No router other than mine and it has been working for almost a year. Hmmmm.
I spent 2 hours on the phone with the ISP. They gave us a static IP hoping that would solve the problem. Like I said earlier, I have the same exact system. Same fiber company, same router, same switches same everything, other than mine being on Windows 10, soon to switch to W11.
I went and checked every one of my router settings and everyone of the BI settings to make sure they all match. Nothing changed and it still does not work.
I talked to them about the ONT and they say they don't do anything with the ONT that should cause any problems. We are going to try a new ONT tomorrow to see if that would work. If not, we are going to switch back to our old system that was actually through them and see if that makes any difference at all.
This system has been in for 4 years. It has worked flawlessly for that time. Then we switch to fiber and it worked for 3 days and then the IP address was changed and it quit working.
We should find out tomorrow after we try a couple of things when the technician comes if it is this new fiber or not. I hope it is but then I hope it is not since I like it other than the BI issue.
